I've also researched cutting brakes more in depth. I always thought that you had to lock one tire at a time in the rear. I guess I got this idea because that's how most people do it because of tractors.
So on pirate I was reading and if you are using front wheel drive to pull you around, people have found it better to have both rear tires locked. Some agreed with this, and some said it didn't matter if they only had one, or both locked.
So on monday night after I got done unloading those transmissions I was dicking around with the cutting brakes on the tractor. This is obvious, but the reason it works so well on tractors is because the other wheel that isn't locked pushes it around.
