That's the mount that Erik was talking about.Quote:
Originally Posted by TxCruzr
mmmm.....Donut
http://www.goodrock.com/productpics/...s/psim0029.gif
mmmm.....Donut
Yeah, same as on a gm clamshell mount basically. I'm betting that's why the block was designed with 4 bolts there to hold the mount instead of two.Quote:
Originally Posted by mudtoy67
Ok, it was just a theory. Cool sig line. :gigem:Quote:
Originally Posted by Fredo
Originally Posted by bburris
too big. doesnt make the power it should and you dont need that much anyways. its not a matter of not being cool, just overkill. sbc are tight enough in a jeep. just sounds like its more trouble than its worth. plus, its a jeep. :flipoff2:
the mounts eric posted up will work if you plate the frame. they are just cantilevered too much. plus, id put the motor where you want it then build the mounts. looks like they put the frame side in then made the engine side to work. i built the engine side bolted the clamshells in and built the towers off the frame with the engine hanging in the engine bay.
Are you talking about building a crossmember that goes under the motor and craddles it? If so, you will probably run into clearence issues, specially if hes trying to build his jeep as low as he can with big tires.Quote:
i would have to agree... if he keeps it low a crossmember might hit the axle
You guys must have the ESPN.
In all honesty, any amount of power is going to feel ridiculous to me in that Jeep. I won't have fenders of any sort, and I put a 1" body lift on to help with hood clearance. That way I can drop it down a little more in the spring department and not worry about tire clearance.Quote:
Originally Posted by agjohn02
The only measurement that I'm concerned with right now is the length. I need to pull the fan off and put some shorter bolts on the water pump pulley and it'll lose about 3-4"... I have a pretty thin electric fan and a 3-row radiator so there's going to be a lot of test fitting, which is why I bought the hoist.
I know I can shoehorn it into the engine compartment, so it really just comes down to the bling factor of having a big block motor in my Jeep. Besides, if we're talking about wasting motors, aren't you the one that put an LT1 in a Scout? :flipoff2:
wasting motors huh? i wasnt talking about wasting the motor. you're right though GM really blew it with that tbi pig.
stretch the cowl :gigem:Quote:
Been getting turned down alot huh...its ok, they make pills for that :flipoff2:Quote:
Understatement of the year. Put a block of wood under the gas pedal. Going from the 1F to the 350 wasn't bad untill the first time I hammered it. Its such a scary rush that you have to do it again and again...hence my small collection of random broken crap. Its worth it though -pimp-Quote:
yeah and its fun to make a toyota go sideways on texas past a big frat daddy powerstroke
