http://centexoffroad.com/forum/viewt...1fe46eeffed375
This is a link to a toyota bumper that a guy did like you are talking about. Has turned out decent so far.
i would stay light as possible since your staying with the TTB. 3/16" should be the biggest you should consider to make everything out of.
nice bumper too, i need to download 'google sketch'. never heard of it.
are you using the pro or regular version?
the bumper design looks good, but iff all of the tube that you show in your drawings is part of the bumper it might have to be changed some, it looks like it will hit the engine crossmember, but other than that it looks good
are each of those plates individual pieces? I just downloaded sketchup and am messing with it, but I don't see any sheetmetal tools. If you think you really are going to build this bumper you would be doing yourself a favor by downloading inventor or solidworks, or using them in the scc.
If you redo it with them, you can get an unfolded model and have it cnc cut. Grinding is for suckers.
I'd guess around 2 bills with material. you feel like sharing that sketchup file? I'd like to see how you assembled that.
robertf2003@neo.
more than a hefty bumper:flipoff2:
that's a really dam good job with sketchup. Did you start with a series of control points or something? Does sketchup let you export to dxf?
And I bet if you spent a few days working on it you could even figure out a hack to get the points' coordinates without buying the pro version! :)
well I'll be darned...soneone's already done it!
http://www.guitar-list.com/download-...les-dxf-or-stl
and apparently some laser cutters will work right from sketchup
http://www.rccrawler.com/forum/showthread.php?t=149650
holdon I got a better mission for you flem: rewrite the software for your cnc dremel to use sketchup directly! You could even do it in 3D! Just think of the potential for re-creating greek frieze and bas-relief art!
oh and your cnc dremel would be way cooler if you made it a cnc rotozip
dam I'm bored...
to move trailers but more importantly a recovery point
I'd like to have a receiver on there because it seems like I'm always doing the trailer moving at work, and my dad keeps our boat at a storage place in tight quarters so it'd make that easier to park it there.
thoughts...try to get the reciever tube moved up, though it would prob be tough to pin. also, move the tow points up. and im impressed with that drawing/software.
With the tow points, I would try to keep them as close to the frame mounts as possible. I would even go so far as to pierce the bumper with them and have them go back 3 or 4 inches onto the mount.
That's exactly what I did, if you look at the mount for the shackle, and the mount for the bumper, they are the same piece of metal that goes through the bumper.
I put a fair lead on the front of it, but for the winch tray, do I just put a flat piece of metal in the back if it to mount the winch to?
Depending on the winch, you could bolt the winch to the 'front' of the bumper. You would then take the shear stress off of the bolts and the force would be directed straight into the face of the bumper.
You would bolt the feet through the fairlead and the two red dots in this picture. Does this make any sense?
Yes, that makes sense, but would 2 bolts be enough to take the stress of a winch?
There would be four, two going through the fairlead, two through the 'red dots'. You would be taking almost all of the shear force off of them also. I had every intention of mounting mine like this, but was running short of time (and motivation).
you may take the shear stress off of the bolts holding on the winch, but it will still be on the bolts holding the bumper on to the truck
move it way up for pin clearance
lets do it
should fit on half a sheet of 4x8
1/8 or 3/16 or do half and half
what does a sheet of metal run these days
no idea, but a fab shop pays less.
but they will still charge you the same or more than they bought it for
I'm not sure what your getting at, in my experience they charge by material used. That other half will go to other customers.
I bought a 4x8ft sheet of 1/4" for $130ish at Triple S in Houston back in the summer time.
go get some mill plate at bryan iron and metal
I got some cardboard from uhaul today.
I think that Cody at Hughes Fab in Navasoto can cut it out for you, he is a TAMOR member but you may have not met him yet. The bumper looks good i like it
you can get free cardboard boxes from the computer labs on campus fyi, they usually have stacks of them from printer paper
