is this a friend that supplies karl with imitation leather?Quote:
It's you no one like's Mike, now your sister on the other hand...Quote:
Originally Posted by BMFScout
Thanks for the grammer help jimmy
Also I dont think you have a chance in hell with my little sister anyway :gigem:
yeah, she seems kind of stuck up to me...
so let's see the new "artwork"
Here is a picture of the artwork, courtesy of J.J's customs, and some parts some people wanted
you're gonna get shot with that sitting in front of your house.
Save the roof for me to paint
Mail it to the NAACP and ask if they will sponsor your Krawler?
I can't wait to cruise that at the Hot Summer Nights Cruise.
This weekend I decided I need to remind myself how much I suck at welding and how hard it is to bend metal. I figured I would fix a couple of holes in the body. I started with the hole by the passenger rear tire. I laid out my plan with some paper, then checked to make sure what I was doing would not rub the when the tires were all the way up. I bought some 16 gauge steel and went to bending. It is really freakin' hard to bend that stuff when you are using your flat bed as a brake. After one failed attempt I managed to make a panel the kind of fit. Then went to welding and beating it into place with a hammer. It truly sucks cause you can only weld about an inch before you have to heat and beat again. Of course the fact that I suck at welding and this is really thin and I was using a stick welder did not help that much either. Anywho, the wheel should not rub, and the rear seat still fits.
Then I needed to modify the door, so I cut the inner skin out, heated the outside up and pounded it around, It looks pretty crappy, but its the klogger, and the door seal still kind of works.
I would have got more done, but the man made me work on Saturday, now for the other side.... and the other gaping holes...
Oh yeah, when I am done I am going to smear body seam filler over the stuff that did not get welded up, like the back area, then I will probably herculine the bottom too.
i would say thats very tacky, but im sure it fits right in where your from... :flipoff2:
do you have a length of chain dragging behind it all the time? :( boo
Hey is that my level :flipoff2:
Just saw the pics from Mardi Gras in New Orleans, its all white people :confused: :D How are you supposed to get your token fat black woman booby pics if its all crackas?
you should have cut on the red line so it does not look that crappy
"Hey is that my level :flipoff2: "
No, its not, I got that when I was working for Budweiser, it's a contractor named Murphy's I found it on top of a pipe, they had forgotten it, so I claimed it :flipoff2:
Gee, Mike thats real easy to do with a red line in paint, if you would look on the inside it made it a lot easier to leave it at that level, and the wheel still clears :flipoff2:Quote:
what does clyde think of all if this tom foolery? P.S i think they had very low ceilings and karl was bounced on people knees alot as a child. Looks good karl, in true klogger fashion... :gigem:
Clyde busy, he is trying to make a faster indian, he has been shown up by that no talent ass clown Burt Munro. He has the fastest Whizzer, now he needs an IndianQuote:
And no, I just huffed a lot of markers and glue, along with living under power lines and eating paint chips...
Well Karl's Rig needs a new tread.
Karl can post some pics of the lastest Klogger.
This past weekend we finished the gas tank install, ran some fuel lines, installed the newer 302 with FI, and hooked brakes and etc up. The wiring needs to be finished on motor and it should be a bad dude.
http://tamor.org/forums/showthread.p...t=big+gay+karl
here you go doosh, i think that thread was just fine.
Man, dejavu...
:laughing:Quote:
Originally Posted by from the first couple posts of original klogger thread
I thought I told you to **** your mother :flipoff2:Quote:
Mike came in this weekend and we did some work on the Klogger Version 2.0. We finished mounting the fuel tank, ran fuel lines, and installed the engine. I still need to put the exhaust on, but the tranny is all bolted in and the shift linkage works. Now it is just connect all the wires.
This should be interesting. I forsee wirenuts and electrical tape in your future.Quote:
It will look better than your getto fabin :flipoff2:Quote:
Karl this is the worst truck in the entire club
agreed! who knew the A&A had wireless now?
A&A?Quote:
Originally Posted by agjohn02
isnt that the name of the motel. i dunno. im actually still in MP. heading out now. see ya suckas.
Kettle, Hi meet world's largest pot!!!Quote:
So does either of your broncos run?
Nope and my furd diesel is not running that great at the moment either. :gigem:Quote:
This is the new klogger racin frame. I am designing it. I really want to see how the forces in that guys frame he is making with out a bender turns out. Turns out I can use a computer too. To bad this program can not do bends. But it does find the forces in all the members. Also you get a pimp stress strain diagram.
| :rainbow:
I got some mad computadora skillsQuote:
Here are some pics Jerry and I took over the XMAS break, got the engine in and the FI 80% hooked up, basically got a FI engine put that in, bought a wiring harness from a junk yard, put that in with some slight modification and mounted a gas tank in the back.
Now the light controls, heater blower, etc... work. It turns over and sparks, need to hook up fuel, exhaust, and water hoses.
it Lives!!!!!!!
Much like someone on life support lives, so does the klogger. After yesterday and today the new and improved fuel injected klogger engine ran under its own power.
Frick put some rear body mounts. Frick, Jones, and Luis mounted the seats. I spent most of the day diagnose Ford Fool Injection along with connecting exhaust, fuel, etc.
Now I have to hook up the front radiator, belt, etc... Pictures to follow.
did you find the right size belt?Quote:
After dinner we stopped into O'reilly's and swapped it out. I think I have the right one now. Plus I got the stuff to complete the wiring.
what's the point?
