Alright dougie, I went to HD today to buy the stuff to make the extension, but I got confused again.
I'm thinking what I can do is use one of those dryer cords with the 4 wires and run that to a 3 wire receptacle in the garage. Dryer cords come with 6', its about 3.5' to the wall. Then, can I connect the 4 wire to the 3 wire plug like we saw at HD? Then I get another 3 wire plug like we looked at, run some 10/3 extension cord material and either splice it in with the existing cord (could use plug from welder) or find one of those black boxes and just plug the welder into that. I still couldnt find one of those at HD, so might have to run to lowes, or do they not make them like what I need for some reason? Otherwise, I could just use a wall mount plug and just build a little tin foil 16/18 ga box for it.
To summarize:
Drier plug from 220 outlet in laundry room to:
3 wire receptacle in garage wall to:
3 wire plug to:
10/3 cord to:
3 wire receptacle to:
welder
Thought again about just having an extension cord, but it wouldnt fit through the door seal with the door closed unless I put a notch in the door jam, which isn't out of the question.
