This. They're 42" tsls. 16.5" rim
I'll only have to take off a hair from the rear caliper but quite a bit from the front.
Really? a 16.5" does not clear? I guess it is the back spacing??? I know your axles are newer than mine, but mine clear 16.5's fine. 15's bring the suck.
Bigger rotors
problem solved:
http://2.bp.blogspot.com/_sLCFVbKl8p...00/stretch.jpg
in 05 they moved to 14" rotors in the front and 13.75" rotors in the rear. I might have to take a 1/16th off the rear. But i'll probably have to take 1/4" off the front.
My 17" steelies have a little over a quarter inch clearance between the caliper and rim, so it would make sense that a 16.5" steely would barely touch. But, since they're aluminum they require a little grinding.
This seems remotely like usable tech information... WTF, get back to discussing porno...
Are you aware how bad those wheels suck? You better get some on board air, and a high lift, and starter fluid, and matches.
Keep it above 9 psi, they are ok.
Looks like i'll be doing some serious fender trimming.
I got them on but I still probably have 30 minutes of grinding left on the front driver. I have alot of material to work with so i'm not worried about the calipers breaking.
http://i736.photobucket.com/albums/x...IMAG0084-1.jpg
Where did you get the tires from?
Wide wheels and no beadlocks? Should be fun!
I really like how Tommy is the only person that will get **** on for going won-tons and 42's :)
He's getting **** on for his wheels, not the axles or tires. That front has 35 spline outters right?
The wheels came with the tires, I'm sure he'll get some hummer wheels soon enough.
Yes sharpe. 35 spline outers
very cool Tum Tum!
Thanks.
I'll be out of money here in a week so it will be a while before I can get some new wheels. But I'll get some of these prolly. Until then i'll just keep 15 pounds in them. Its not like I have the gearing to crawl anyway.
http://www.trailworthyfab.com/145-Do...l-Special.html
Cute
Do it!
If you did that, you wouldn't have room for your spare alternator. :flipoff2:
Pretty sure he never finished that.
This would be a fitting end to the life of this Bronco
So... Are you wanting to do this to your bronco? or are you wanting to find a truck cab to do it to, then slap it on your bronco's frame?
Haters gonna hate
Yes. What Clarke and Sharpe said. The cutting wheel is where it will go to die, a la Doug Krebs.
Haha, awesomeness!
I think those 42's look badass and don't even mind the wheels.
sweet flex bro!!!
I think the carnage should be epic
hahaha
awesome
Looking good!
