do you really need those spacers on the rear with it being under a jeep? oh and it is looking good
ahh, i've heard that before, it seems hit or miss if they fit over hubs or not
Will had them on his 10.25. he clearanced them with a grinder. They dont fit over mine because i have disc. I could have ground them more but didnt want to
If I remember right, we had to clearance the ones on Kurt's YJ to fit over a 14 bolt.
go have a machine shop cut them out for $25 a wheel.
i have a better set of wheels already... they are still on my old 40's though. Will needs to hurry up and get new wheels
awsome!!!!!!!111!!!!1
it will be fine... and if it isnt... then i will fix it... what of it
so backs done. kudos. hows progress on the front...
Did you weld a plate to the inside as well? Are there and cross members between the t case mount and rear bumper?
didnt do inside because i have some factory stuff to trim off still... it is in the plans before i finish it all... front has not been started at all. rear looks like pic... no rear bumper though
what did you do for body mounts?
They will be added to the crossmember in back
