Fair enough. How likely is it that anything behind the yoke and seal need attention? I already bought the pinion seal at oreillys, but I'm going to order this: http://broncograveyard.com/bronco/i-...ge-3-7-8-.html
to replace the 9" yoke. What size is the pinion nut? 1 1/8?
Also, FWIW.. I plan on draining and changing the diff fluid in the 9 inch. I'm not 100% clear on the procedure for this. From what I've learned, I have to pull the axle shafts and the carrier. Is this true?
