Well, it's full, and I don't have any extra parts.
A couple of tips for anybody rebuilding one of these;
Buy the ASTM manual
Make friends with somebody who has the special tools needed for this transmission, it's doable without the tools, but it's probably way easier with them
If the pump won't seat into the case, loosen the bolts holding the pump together, take the seals off of the pump and set it in there, pick it up making sure the 2 halves don't move and tighten the bolts then set it in there again to make sure it seats and then put the seals on and seat it in the case for the last time
Don't rebuild it in your second story apartment
Take pictures of where all the check balls are before you let them all fall out
Don't let anybody tell you it's too hard
When a part has UP on it, it doesn't mean how it would sit when in the truck
Here's 2 write ups with pictures to aid your ASTM manual.
http://www.thedieselgarage.com/projects/e4od/index.htm
http://www.fourdoorbronco.com/board/...3-E4OD-rebuild
I might put it in Saturday but I still have to run some new lines to the cooler and figure out how to mount my temp sensor.
