i need an outer stub shaft, where is a good place to buy one?
It's 35 spline yes? If only 30 spline, I have some extra spares to offload.
if its 30 spline i have one ill sell you
35, i want new not used. Is cro-mo worth it?
do they sell a non chromo 35 spline stub?
stock, d70
"Stock" stub
https://www.4wdfactory.com/store/pro...340-outer-axle
Yukon chro-mo. Wtf, this one is cheaper than a "stock" stub??
https://www.4wdfactory.com/store/pro...2C-Yukon-1541H
Superior chro-mo. $$$
https://www.4wdfactory.com/store/pro...7%7D-35-Spline
first one isn't stock, its from a manufacturer called ten factory, not a factory axle shaft, its still an upgraded shaft
Hah, didnt read the description...
I'd say yes, since you have very manly tires. But then the rest of the shafts are probably stock. If you don't mind dropping the money, put a fresh set of chromo in the axle. Dave will tell you after some years the ears in the yokes of the stock shafts stretched on his. Not only is the material stronger, there's much more material on the yokes, at least on the Yukons I have.
If you're just buying one piece and are willing to replace as you break them, still probably good buying 1 chromo piece at a time, it's not much more than new stock.
chromo shafts are worth it but it is still hard to find the cheaper import chromo shafts
i would just go with these, BTW 4wd factory is out of hutto just north of austin
or these for chromo
https://www.4wdfactory.com/store/products.php?product=Dana-60-Outer%2C-Yukon-4340%2C-30-{47}-35-Spline
need to change the front arms for more turning radius. saw these, any thoughs of building something this style?
http://www.therangerstation.com/tech...radius_arm.JPG
also need to upgrade my 60 knuckles before the break. who makes gusset kits and who had better after market ones?
