:laughing:
i pooped in november.
If you only did it once, then I can see why you are in such a bad mood right now. ;)
So extra parts...
I have none... Should I go buy some an extra U-joint for the front? Try and see if I can dig up some shafts? (D30/D35c) I know someone said they had a shaft for the 30, and another person said they had a shaft for the 35?
U-joints & fan belts are always a good idea
I wouldn't stress too much about it. If you can find some spares cheap or going price get them, otherwise you should be ok since your diffs are open. (they are open, right?) You can get ujoints for the front, not a bad idea, but it is rare that they break and not destroy the ears on at least one of the shafts when they go. Better to have a whole assembly to slide in and worry about salvaging what broke when you get home. There is also a pretty good NAPA in town, I got a brake line one year that they shipped in from somewhere, nice people.
the most commom breakage is U-Joint straps, buy a spare set of those, don't get the crappy ones in the help section, get the ones behind the counter.
precision makes some decent u-joint straps
agreed, if you listen to others in the club i wouldn't worry about the ujoints, It took me quite a while to break a ujoint with 33's with a locked diff
agreed, but if ujoints lived for me then they should live for most other people esp those with a 4cyl
Do you think I can carry an axleshaft on the airplane
Edit: i doesn't say no but since it says no baseball bats, I would assume no
