I have never actually broken a driveshaft u-joint. Usually when they pop out it's a result of axle wrap. I do/did wear out 1310 joints of all brands very quickly though.
Even Neapcos?
Lucas HAS to make some kind of bandaid miracle cure for u-joints. They do for everything else!
ive broken a precision ujoint. do i get a cool kid sticker now?
I broke a precision ujoint in Reno, just to watch it die.
:laughing: :gigem:
I broke a precision joint in oklahoma...
I got the transmission most of the way back in. After it's in I just need to finish running cooler lines and I would be driveable but it's coming apart for the old klogger lift and the sterling rear end. Also found out that there's a coolant leak somewhere near the rear of the engine. I'm not going to trace it down; just hope it's not leaking into the cylinders and start building a replacement motor, maybe a 460, maybe a 351. Depends on what I can find.
