are these long headers or short?
short
si, you just need really good gaskets cause they tend to leak
Through a strange course of events I got today off and drove back to CS to work on it some more. The wiring harness is hooked up. The upper intake is cleaned up and bolted down. I cleaned it and painted it with some high heat aluminum. I thought it might look ghetto/chrome, but it actually looks really good, like a new part. Core support should go on this weekend
Waiting on a new throttle cable, egr block-off plate, and ps pump
I need a new steering pump, but do not want to fork over for an AGR. I am thinking about this pump...
http://www.partsamerica.com/ProductD...tnumber=206244
I think this is just an improved version of the stock pump.
Ryan, don't you know how to modify these to flow more?
only the saginaw's, but i heard a lot of good thing about using that bolt in saginaw pump but i cant remember if you need a new high pressure line or not. I know on the bronco once i put ram assist on it there was no need for more flow
I plan on going ram assist here shortly, but I need a new pump to start with so I think I am going to get that one.
Apparently you need a high pressure line from a 78-79 bronco.
Well make sure the saginaw pump you get is from a 70's vintage vehicle because (at least Chevy/GM) used flared connections with SAE fittings in the 70's but switched to o-ring connections and metric fittings from 81 to present.
hey john i heard those arent all that great. i have a buddy who has gone through 4 already in 2 years. 2 just snapped the shafts on it. what i did on mine was find a power steering/ AC bracket from a e150 van with the same engine as my truck, installed that and got the pump from the van. they come stock with the saginaw. then i got the high pressure line from the van also, they follow the same route as the truck/bronco pressure line untill it gets to the pump. thats another way to work it anyhow
so e150 pump is a sag pump, but will only bolt up to the e150 bracket? I assume I would need to find one with a 302 or 351? What years?
yes it is a sag pump.
-Saginaw pump and bracket come from 1987-1997 ford 302/351 vans.
-302 and 351 are the same bracket so it won't matter which one you get.
http://www.fullsizebronco.com/forum/...d.php?t=115063
but if you search on FSB there is a sag pump that you can buy that bolts up the your current bracket, it is an A-1 part and i think all you need to do the swap is a new high pressure hose
