this is not what we are talking about. mass flow is not going to be your problem. the problem is you're only pulling air through about 2/3 of the area of your rad. the other 1/3 is going to have little to no airflow over it on the trail. im sure the fan is adequate, you just need a bigger shroud. if you have room for it, which i doubt with the 258, go to eaker and see if he has an aluminum shroud you could put between the fan and rad that will cover the rad. my scout rad is only about an inch wider than yours and the taurus fan fit well. im not sure on the height difference though. there are plenty of cars out there with good fans and small radiators.
