fixed it for you:gigem:
Started screwing around with the serpentine accessories tonight. Figured out I need a reverse rotation water pump and that the pulley's accidentally got recycled at my friends shop. If anyone has the water pump and harmonic balancer pulley for a serpentine setup let me know.
I'll start working on a bracket similar to this soon for the york. I can't believe they charge $160 for that...
Picked up the scout frame last night. In really good shape, just a little surface rust. It's going to take alot of cutoff wheels to cut off all the factory brackets.
I need to decide on a frame width. Maybe I'll chop the body first, and see where the mounts are at. Definately want to have a flat belly, so it at least needs to be as wide as a transfer case clocked up.
Deep thoughts, by Doug Krebs:flipoff2:
sweet blog. Don't you still have a torch?
you don't have a plasma at work? I'd tell them they should get one. I guess you won't be using much on it, but the rear crossmember is junk as you can see. Other than that I think it's a great frame and probably why the scout weighs as much as it does. The original drivetrain is all above the frame, so it shouldn't be hard to do on this project.
what t/case?
I found that a sawzall works faster and better than the cutoff wheels, but a torch is the fastest just be careful not to blow any extra holes in the frame
If you dont have a 241 already I have (IIRC) 2 np242's and one np218. They are out of military hummers and the front half is more or less identical to a 241 and 208, respectively. The only major difference that I can see from the outside is the hummre cases have cooler hose barbs and from what I've read online, they are fulltime 4wd. If you are interested in trying to use them, I will give you one of the 242's if you help me make a version of the doubler. Since The 'Corn will never actually exist we can test out whatever you come up with in Pigpen. If it will hold up behind the 8.1, it'll hold up behind whatever turd of a motor you decide to use.
