couple more fires and it will outgrow it.Quote:
Originally Posted by 85cj7
does the datsun come with a title?
yah i'm going have to move it soon, because every time the kiddies have a fire it shrinks from the heat.
jump it
get it, weld the rear and pull out the sawzall
this is what i have decided!
get it, weld it, sawzall all unwanted sheet metal, build some different bumpers and maybe some sort of cage, and wheel it till the wheels fall off!
And fix the headlight on the dodge
Looks like a solid start, might be able to get it for $200! :)Quote:
Originally Posted by Eckert
I'd bet on the scout for the same money.
You can wheel the Datsun 'til the wheels fall off, but I'm also betting it will be the first run to 47. Which for $300 that is fine. I just dropped $300 for 3 tickets to a football game, you will get at least that much enjoyment out of it. Also, if it gives you something to wrench on, you'll learn a lot, just don't listen to Sharpe! Worst case, it breaks something then you patch it together and see how far it will launch.
This isn't entirely true. The front output on my case was a slip yoke. Last time I checked, no one makes a slip yoke eliminator kit for a Mazda. In addition to that, the front output points up a little bit and there was no way I could find a driveshaft that would have made the drop. I would have had to move the axle pretty far forward. There are some details that need to be looked over on that truck before it is determined that a SAS can be done.Quote:
Originally Posted by uglyota
It's all in the details. I could SAS my little bro's bike given the proper tools, material and time. Nutz, you sir are a DS. It's that kind of thinking that got everybody to raggin on you about your pile to start with.
:flipoff3:
it couldn't hurt to offer him 250 or even less
good stuff.
he wanted 400 cuz thats what he paid then he put tires and a new floor into it so 300 is good i think
It's a good deal if you are happy w/ it, no matter what you paid or what some of the joos around here tell you. :D
Thanks :cheers:Quote:
sometimes being Joo pays off.Quote:
