I think they came from meQuote:
sweet. i don't remember if i said thanks or not. but...thanks....they worked perfectly and it was a damn good deal.
Now that my POS truck runs and wheels reliably (after i fix it again of course)
I want to make an onboard air tank. Is there a cost efficient way of doing this? Say weld or bolt a good size propane bottle underneath (i have alot of room) and run lines off it? i don't need to run anything awesome or anything. Just something to have about 300psi of air handy or so when i air up or happen to blow a bead. School me on air tanks please. I'm stupid.
i got mine off ebay its just a simple 5 gallon tank of a 18 wheeler trailer with a 250psi max, i think it was $9 then like 15 sp&H
sweet...send me a link.
http://cgi.ebay.com/ebaymotors/22-x-...00043675QQrdZ1
thats all i could find for now, there are bigger one with higher pressure ratings somewhere
sweet.
The picture is really dark...what all does it look like? do you have a pic of yours? Also, if i keep this tank at 150-165psi, it wouldn't have any problem airing up all 4 of my tires from 8 back to 20psi would it?
Well i found the 8.5 and 12 gallon tanks on ebay. My buddy says he has some tanks laying around that i may be able to have...so i'll check that out first. My question is that if i fill up a ~10 gallon tank to 170psi how many tires will this air up? How big a tank do i really need? of course i'll go home today and see exactly how big a tank i can fit. Most i'll ever do with it is probably air up tires and put tires back on the bead every now and then. Maybe have an airhorn...but prolly not. We have a big compressor that will push out 180psi here at the shop, so filling it will never be a problem.
Boyles' law
p1v1=p2v2
volume of your tire=a cylinder 38" diameter and 15" tall minus a cylinder 15" in diameter and 15" tall
volume of your cylinder=231 cubic inches/gallon
pressure has to be in atmospheres: 1 psi= 0.068046 atmosphere
onlineconversion.com is your friend!
you can always build a CO2 tank setup for pretty cheap. Botco has the regulators, you can get the tank on ebay (harbor frieght had one in the close out section as well recently), and the hoses and fittings can be had cheap at HF as well
ok....tell me about that.
ya CO2 would be your best bet if all u want to do is air up tires
IF you want to see one you can come over sometime and look at mine. The tank is the hardest part to get. Ebay is a good source. You can get 5, 10, and 20lb tanks. I run a 5lb. I just had it filled for the first time, so I can't say how long it will last, but I know it will last much longer than a normal air tank. Creighton has been using one for a while, so maybe he can give you more info on how long they last. You may also be able to "liberate" a tank from a convienence store or something simillar. They're used to run the fountain drink machine. Then get a 100psi regulator from botco. They had several on the wall over by the welders last time I was there. Then go to Harbor freight and pick one of those hose kits that come with all the fittings, and a gauge if you want it, and you're good to go. The nice thing is, these things are relatively small and compact, plus they're mobile, so you can carry them to other rigs. As for price, I bought the tank for $40, the regulator was around $40, and the hose kit was $15 (but I got the one with the better hose). I think it was 9 bucks to fill it at brazos valley welding supply on 2818. I built my own mount for it. Here is a pic
http://www.tamor.org/members-rigs/al...3/100_0025.jpg
Supposedly you can also run air tools with this setup, but I don't know if the regulator from botco will work for that or not. Perhaps do a search on pirate for more info. Another thought on the tank. Maybe try checking with Brazos valley welding supply and see if they will rent you a tank for a few dollars a month, and then you could just come trade it in for a full one when its empty
Great tech, thanks....thats what i was looking for. That sounds like a great price. I was looking at these MV50 12 volt compressors that sell for ~60 bux today. I was thinking about doing that + about a 10 gallon tank or so.
So whenever you run out of co2, you just go to BVWS and they'll fill it back up for 9 bux? Is it safe if i put it between the seats and mount it against the back wall? I used creightons once to air up a tire at TCCIII.
yeap, takes them like 5 minutes to fill it up for you, or you can always go back and just have them top off the tank for you. If it fits, you could put it between the seats I guess. CO2 isn't flammable, but of course is still under pressure so there is a little danger there. But then again I drive around with a propane tank right behind the seat. One nice thing to remember is you never have to worry about one of these burning up or wearing out like you would a air compressor.
Also, with the CO2 tank, it can run a kegerator. Nuff said.
I'm going to do a 10lb or 15lb co2 tank and place it between the seats against the back wall. My buddy says they've got 10lb tanks so i might be able to get one for free. From the looks of it, a 15lb tank will fit where i want it too. thanks for the help.
http://cgi.ebay.com/ebaymotors/Inter...75502991QQrdZ1
is this a 1310 yoke (like the 1/2 ton chevy) or the smaller jeep kind?
it should be at 1310. to be sure ask him to measure the diameter of the caps, and the width of the ujoint and compare to a 1310. or look up on internet
K, i have a 10lb co2 tank being shipped to me. I have to save the 60 for the regulator. I Po.
Obviously, i need storage. (ever seen all the **** fly outta my bed?) Im going to buy a few ammo cans...bolt em down in the bed.
I found this place that sells em for cheap, but i don't know how much shipping will be....hopefully not that much since its from OK. Anyone else know where to get them (this cheap)?
http://www.calumetindustries.com/ammo.html
figured get a
.50 cal for hand tools/wrenches and fitalls
.50 cal for sockets/ratchets
20mm for fluids and spare parts
20mm for big tools hammers and breakers and whatnot
.30 cal for a center console between the seats....right behind it on the wall would be my co2 tank.
any suggestions?
there is a military surplus store on texas by campus, and another one near sears in the mall where you can get ammo cans. Surpluscenter.com also sells them pretty cheap, but shipping on these large items is the killer.
