Originally Posted by hrod79
So I looked and it seems that the BIO0 and AKC0 EEC's are the only ones made for the 5.8L engine. Would the others made for the 5.0L not work appropriately? or would there be any issues?
Yes, they would work appropriately for your relatively stock 5.8L.
A common MAF Upgrade consists of the use of the readily available 1989-1993 Mustang
A9L (Manual Transmission) or
A9P (Auto Transmission) EEC, which would require a separate Transmission Controller for the E4OD. This is popular for a non-electronic E4OD Bronco application as they are readily available and the separate Transmission Controller is not an issue.
The
WAY1 and
VEX1 EEC's are from a 1995 F150 5.0L EEC-IV/MAF/E4OD/OBD-I and support the electronic E4OD. They should work fine in a a relatively stock 5.8L, but if you begin to significantly modify your engine then custom tuning through the J3 Port (by way of a custom chip or on-board tuner) may then be required.
Issues in a MAF Upgrade consist of relocating the
ACT Sensor from the existing Speed Density Intake Manifold location to the MAF Air Filter Box location due to the existing MAF EEC programming. I personally had the Bin File changed in my custom tune to address the different temperature values and kept the ACT Sensor in the existing Intake Manifold location.
Another issue would be the addition of an additional
HEGO Sensor. The
WAY1/VEX1/AKCO only require the single O2 Sensor already located in your stock location. The
BIO0 and
A9L/A9P will require welding in two sensor bungs to provide for the addition of specifically located stereo O2 Sensors.
VSS should not be an issue for your 1995 Rear Differential located VSS. It was for my (pre-1992) 1990 Transfer Case Tailhousing located VSS.
So far I found two BIO0 EEC's and looks like they would be chip programmable. Would that be the best option because it is specifically from a 5.8L engine?
The BIO0 would be a great EEC for a relatively stock 5.8L as it is from a 1995 California 5.8L EEC-IV/MAF/E4OD/OBD-I Bronco. Addressing the ACT location would be required as well as the addition of stereo O2 Sensors. Problem is the BIO0 is rare and expensive as it was only in the 1995 California 5.8L Bronco.
On the other hand, the AKC0 may not be a good choice without tuning as it is from a performance modified 1993-1995 Lightning with 24 lb/hr fuel injectors.
In summary, the
WAY1/VEX1 are the easiest to use for a MAF Upgrade on your 1995 Bronco. They not only have very similar Bin programming files, but there is a lot of support for tuning. Additionally, they are EEC-IV/MAF/E4OD/OBD-I, which only require your existing single Oxygen Sensor and they have a J3 Port for future custom tuning. Without a custom tune, you will still have to install a MAF Air Box to accomodate the relocated ACT Sensor.
If you can find a good
BIO0 and are willing to spend the money, it should also work wery well for your 5.8L/E4OD, provided that you address the ACT and stereo HEGO Sensor issues. The advantage of the
BIO0 is that it was programmed specifically for the stock 5.8L Bronco.
IMHO, no matter which computer you use, a proper "tune", or reprogramming of the PCM, may be in order for your specific build. Many will attempt to do a MAF Upgrade on the cheap with a closely matched PCM, such as the 5.8L BIO0, attempting to end up efficient. It may run good but unless you provide a custom tune, or install a on-board tuner, you will be settling for "good enough". You may never achieve the most optimum air/fuel ratio over your performance curve.
Upgrading to an MAF EEC having a J3 Port will allow you the flexibility to address tunig at a future time, if desired.
See the MAF Link in my signature.
