as long as you dont use kopecki oilfield pipe, it'll weld fine.
http://www.ballisticfabrication.com/..._p_7-1557.html
doug can you make something like this but with either 7/8"-18 or 3/4"-whatever?, to fit into square with an 1" i.d.
call ballistic, they'll make them for you, it's like a 3-man operation, nice guys
do that cook and order me some also
or you could order the round tubing and adapters off of the same website and from the looks of it spend less money :flipoff2:
i think 7/8-18 in a 1" id hole would be bad news
thats what my steering has, you just have to be careful when welding them, i had one end up with ****ed up threads after weldingQuote:
square tube is cool :gigem:
Yeah... I have 7/8 -18 taps... 3/4 would depend on the tap.Quote:
Originally Posted by RCcola55
$17 is cheap for that. I'm assuming they either use a CNC or a jig and make alot at time.
I'm not sure it would be worth my effort to make for $17.
I was thinking the same. The page said they have a 4th axis mill, so it probably takes less than a minute for them to make one. You'd probably have to swap out a 4 jaw chuck in a lathe, flip the thing around 4 different times on the mill, and still have to order material.Quote:
i have a bad feeling that the high steer arms are not going to clear the leaf springs...
if they do, they make spacers, but i have no idea how they would work on an off road truck
can you post a picture of the setup?
i will once i get the rear put back together. i'm not done with the gears yet.Quote:
Originally Posted by bburris
needs more cowbell
finished up today. just need to wrestle it back under the truck. i'll be happy if i don't have to mess with gears for awhile.
did you do what i said?
