i dont remember what you said, something about subtracting and adding .010".
backlash is .008" which is what the instructions with the gears said to have.
pinion preload is about 25 in lbs. which is the average between the new and old bearing ranges.
i had to hammer the carrier in with the dead blow, so the carrier bearing preload is probably good.
and i took pictures of the pattern
what else?
