I'll play with it tomorrow but it is really close to the back of the pumpkin as it is.
Steering solution.
http://i406.photobucket.com/albums/p...p/DSC03134.jpg
Parts list:
-1.75"x6.75" single ended ram kit
-Modified psc gear box for cylinder assist 25/76 metric gear w/ 13/16 input
-1400X series pump
-6.5" remote reservoir kit
-1300/1400 series pump retrofit bracket for 5.0 Ford Mustang pump bracket
-Modified stock pulley
-12" heat sink cooler kit -6 fittings
-Cylinder hose kit w/ 4-90s 6' of hose
-6 x 18mm x 1.5 0-ring adapter
-(2) A2 #6 field servicable 90 degree
-(3) A2 #6 high pressure hose LG OD
http://i406.photobucket.com/albums/p...p/DSC03145.jpg
http://i406.photobucket.com/albums/p...p/DSC03144.jpg
http://i406.photobucket.com/albums/p...p/DSC03143.jpg
http://i406.photobucket.com/albums/p...p/DSC03141.jpg
http://i406.photobucket.com/albums/p...p/DSC03140.jpg
http://i406.photobucket.com/albums/p...p/DSC03139.jpg
http://i406.photobucket.com/albums/p...p/DSC03138.jpg
http://i406.photobucket.com/albums/p...p/DSC03137.jpg
http://i406.photobucket.com/albums/p...p/DSC03136.jpg
did you buy the ram seperate?
No, it's psc just forgot to list it. Thanks for pointing that out.
is it the 1.5" 8" travel ram?
I see the edit now. How did you decide 6.75" ?
Before I tore it all apart I found the axle center-line and marked it with a chalk line then I pulled the wheels to full lock right and marked a chalk line on the tie rod that matched the axle center-line mark. Then I pulled the wheel to full lock left and marked another chalk line on the tie rod that matched the axle center-line mark. Then I measured the distance between the two chalk lines on the tie rod. It was exactly 6.75" throw. I was just lucky in the respect that PSC has a 6.75" throw ram. Because you want the ram to be the limiting stops in the system it worked out perfectly, otherwise I would have had to run the 8" stroke ram and have added internal stops.
I wanted to change the look of the cage up a bit so I added a bar running across the top of the each wheel well and a double B pillar with some small 'rungs'. I have always liked the look of the double B pillar and it adds some uniqueness.
http://i406.photobucket.com/albums/p...p/DSC03146.jpg
http://i406.photobucket.com/albums/p...p/DSC03147.jpg
http://i406.photobucket.com/albums/p...p/DSC03149.jpg
New D-44 3/8" cover
http://i406.photobucket.com/albums/p...p/DSC03358.jpg
$5 worth of black clothing dye makes a huge difference on the harnesses.
http://i406.photobucket.com/albums/p...p/DSC03357.jpg
Did you buy a weld it yourself kit or did it come welded?
Does it leak?
It's been on for over a month with no signs of leaking or weeping.
I got some custom cowl armor made up for the cj and bolted it up last weekend. It covered up the dent in the cowl from the last flop nicely. :D I will add some tube and extend it off the fenders and tie it into this new cowl armor plate. It is 3/16" with (10) 5/16" countersunk stainless bolts, just like the rest of the jeep.
Again, trying to stick with the 'unique' look. I'm not a fan of the new two-tone paint scheme. But that should change soon. :gigem:
http://i406.photobucket.com/albums/p...p/DSC03368.jpg
http://i406.photobucket.com/albums/p...p/DSC03369.jpg
http://i406.photobucket.com/albums/p...p/DSC03370.jpg
http://i406.photobucket.com/albums/p...p/DSC03372.jpg
Most recent off-roading trip compilation from last weekend.
http://www.youtube.com/watch?v=qy1uy...=youtube_gdata
