duramax is different breed from a mechanical cummins 4bt. duramax's are common rail and run electronic injectors that can be held open at different intervals/durations. 4bt's timing is linear in that it is fixed and uses mechanically timed injections of fuel and a poppet style mechanical injector. can't compare the two except that they both use diesel fuel.
