Yeah I got one on order. Nah you can send it to me. I have no been to see karlisa in awhile.
Flemco is buring me a chip. This should solve the firing order issue and let the computer control the electric fan which will be pretty cool. The smog pump has been disabled as well. I have the wiring harness fit to the bronco. I just need to tape the harness up and zip tie it in place.
I need to pull the headers and weld in the 02 sensor nuts and wire the fuel pump. I would have finished it this weekend but I went to CS to drink. Maybe this weekend it will be running again.
Hey Flemco did you put that chip in the mail yet?
I've tried running it with the pins in the original position as well as switched, both worked fine.
Originally Posted by 73bronco
I am gonna run the pins the way they are until flem & company burns me a chip.
Well I dont have any new pics it pretty much looks the same. Jimmy it still has a flat tire. I have it all wired up and ready to start but due to the rain I did not want to plug my computer in just yet. Hopefully some time this week I can let the wiring harness dryout and try it.
theres the tranny mike, let me know whatcha think.
you should be able to tell if its electronic or not by the electrical connector. at least i know on chevrolet AODs that the easiest way to tell.
that doesn't look like the turd AOD I have sitting around, so its at least an electronic shifted tranny.
my buying strategy= what is it going on ebay for-what are you asking = GP
no kick down lever its a AODE. I need too see how i can make it work.
thats an e4od, still electronic controlled just a much bigger, heavier, stronger version
I pretty much worked all weekend on my little bronco. Its being a pain in the butt. I got it kick over a little I have some sensor problems to work out.
I have been working on this dude but can not get this to fire. I have replaced the ICM and the coil and getting nothing. I get a fire every once in a while. I think I messed up the wiring some place. Gonna have to check all this again.
I also bought a 89 KLR 650 dirt bike and it runs so I might play with it.
hey mike there is a diode/resistor combo somewhere inline with the ICM plug and ecm harness that kicked my ass. I think the wire is green, maybe has a stripe. The solder joint inside the molded plastic case broke and I had to splice in a junkyard replacement.
I can't remember if eec-iv won't start if the park/neutral condition isn't satisfied. My diagrams aren't handy but you might want to check that.
Flem you are out standing. I did not hook that wire up I thought I could make it with out that.
1989 KLR 650 34,000 miles 700 bucks to good of a deal to pass up
sweet....
you wouldnt like that bike... he said it runs. :flipoff2:
I've wanted one of those for like 5 years, but I rode karls and its too tall for me....good deal though!
you air up that tire yet on the little gay bronco?
NoQuote:
It does run now.
Thanks Flem damn tranny wire was bustin my balls.
Jerry they make lowering kits for them so you can get one. :gigem: I know this because my rear shock is broken and I was looking into buying a new one.Quote:
I think you should start a new thread...
Turns out this my damn thread and I can do what I want :flipoff2:Quote:
Just to make krebs happy. My little bronco runs pretty well. I still need to work out some kinks with the Flemco chip and work on the brakes.
Ehh, I have been told that if I make any other "stupid" large $ purchases before making a certain other purchase, I need not worry about having sex for a while.Quote:
Man thats great, if you can get the whole sex thing out of there it is such a relief!Quote:
SUCKER!!!!
Speaking of that I heard you're eating steak-ums tonight :confused:Quote:
Well after you make a purchase you can get a bike
Nah they are gonna go kill some baby seals or something. Karl make sure you wear your blue sweater too :flipoff2:Quote:
all my friends that get married buy everything they want whenever they want!Quote:
I have no idea what that even means, but just to be safe :flipoff2:Quote:
I have no idea how this broke but it was broken when I got the bike. I am guess some fata$$ bigger than me road this dude.
Edit yes those are steps like you see leading up to a trailer house. I did not live in a trailer house the owner is to much of a joo to build a deck I guess.
This is for Jerry I know he wanted to see a damn pumping unit.
Typical oilfield crew, 5 workin 7 supervising!
Hey my house has those too....
What does that prove? :flipoff2:Quote:
whats the chip do?
I have not tried the chip out again. I will give it a shot and see what it does.
Flem
I got around to testing the Chip other than the fact that the fuel pump will not shut off it will run on that chip. Its surges a little but I think the computer is trying to figure out what the hell is going on.
If we could get the fuel pump thing to work right that would be super. It also starts alot easier with the chip in the truck.
