Originally Posted by
KrazyKarl02
Carnage:
Flem - Rolled Disco - bent roof cage, bent sheet metal, busted tail light. Sunday he discovered he had broken some rear axle flange bolts
Frick - Huffed the motor, started making noise Friday, he ran it all day Saturday until about 5:00 pm, then while extracting him, we de-beaded a tire
Heath (my neighbor) - Cracked his transmission in half
Hippy - Think there was a broken anti-wrap bar
Sam (In Jimmy's rig) - Broken rear axle shaft
Fred - Spit a u-joint cap out on a front shaft
JB - Broke a front shaft, repaired and continued wheeling
BDR - Poked a hole in his transmission
Evan - mystery jeep no start issue
Klogger - Friday had to tighten the t-case yoke and replace a hydro-assist hose steering fitting. Worked great until Saturday night when I broke a u-joint strap, which sent the driveshaft into the break line. Repaired the driveshaft, but no brakes. Then while finishing walk in the park, rolled on side (from what I am told it looked violent, I was quite comfortable) Upon righting the vehicle the power steering pulley exploded, leaving me without power steering, charging, or cooling. Then the starter solenoid decided to break. While being pulled back to the parking area I was unable to steer and became intimate with a tree on the passenger side, more body damage. Sunday morning when I awoke I found I had cracked the frame on the passenger side, significantly, in 3 places, but there is nothing wrong with the radio!
