I found out the other day that they are making a thin mint-flavored moon pie. I have to have one!
and I could really use some coco loco right now :flipoff2:
I don't mind carrying a small spare tank full on the trailer as long as I have enough to last a good solid day. Even when we were in Co., we were always back at camp. I just don't see the Beast as an 'expedition' type vehicle.
luk makes most of centerforce's clutches
That tank should work just depends on the pick up style and baffling
what no propane?
I think I have talked them back into putting the dual mixer propane setup on it! I think I am going to have to do awful, awful things for Flem to get him to still work on it though. :(
List of ****...
Gears for 60 (they are trashed pretty good right now) and rear axle shafts for the 70 (Yukon is a sponsor of the event and I should be able to get them at a discount/free I hope)
New Flange for front of atlas (from high angle, this will make it easier to remove the shaft if needed)
Power Steering Pump (psc)
starter (get from napa for the warranty)
20" Beadlocks for Claws???
make sure to keep your stock axle shaft so i have some spare when i am wheeling with you
I still have a set of 1451's to put in that I don't plan on changing till I break another stocker. :D
I was thinking, how wide are your rims that you have now? I might want to try and 'borrow' them to get the set of claws. Do you have any rock rings for those rims? I may have a set of the aTm ones at the house for the H1's that could be turned down to fit I think.
brians are 16x10 i think w/o rock rings
There sjould be a brand new psc pump in one of your green rubermaid boxes that live on the trailer
