Go to pirate4x4 and search.
I think the common tj swap is the dodge 3500 master/booster.
I have the yj booster with corvette master but I don't think this is the combo you are looking for.
Worth j-yard shopping or should I get new with warranty
Year?
brakes is something i always buy new. dont' want to skimp there
Does anyone know of a place in town that sells gresable 9/16" bolts? I already called Mack and they said they did not carry them.
these look pretty cool. . .
http://pirate4x4.com/forum/showthrea...=873932&page=2
but i think for the price (and how simple they are) that I would rather build ones that go all the way to the spring pad.
So lets say someone wants to run some 52" chevy springs, you take the overload spring out because it is geah. You also want to add an anti-wrap leaf to reduce axle wrap. Where would one buy such an anti-wrap leaf. Clarke and Cooke should know this.
What the hell is an anti-wrap leaf? Do you mean like a military wrap leaf? Or just another main leaf staked on top? Sounds like you need to make some bastard packs.
No that's not what he is talking about travis. Karl call alcan spring and see if they can make you a mil wrap for chevy 52" springs.
Is it too tight to put in an anti-wrap bar? Seems it might be a tad more work, but by the time you buy aftermarket springs, you shouldn't be that much more into it w/ a johnny joint and some bushings like I have on mine.
(Is this for the front or rear axle?)
He's not talking about military wrap...anti-wrap:
take a main leaf from another spring pack and cut off the eyes and bolt it in. that helps. thats what is done to xj leaves so they don't wear out so fast cause there hella flexy and can dearch quick
You're right, bad pic. I was thinking more along the lines of what toyota runs with the clamp made to the "overload" leaf to make it anti-wrap.
http://img43.imageshack.us/img43/9087/springsn.jpg
karl, i am running stock 52's for my fronts with the overload removed and the wrap is not very noticable at all, for my rear i am running stock 52's with the overloads and there is a little wrap but it is also not that bad
I've never had any noticable wrap issues with either my front or rear leafs. I have 56's with a 2" add-a-leaf in the front and 56's in the back.
What is this hot pocket love you speak of?
Hot pocket gets no love :flipoff3:
As much as it pains me to admit it, I agree with Seacrest. Alcans are retardo-expensive for leaf springs. Deffinately not Klogger budget-ish.
Previous owner of the taco had alcans made up for the rear. They are super nice but I don't think I would drop the coin on them myself... The sure do flex nice and have never lost any arch tho.
As I understand it Clarke had 52's on his Bronco and everytime the sun came up the front axle would wrap, trying to prevent this in the most cost effective manor. So far it looks like cutting a main leaf's eye's off and throwing it in is the most effective/economical.
Where can I get the metal sleeve that goes inside a poly spring bushing? A couple of mine are starting to egg out? Does any company make one that is fully welded?
If the insert is getting egg shaped, that probably means the bushing is hosed or you have too much tolerance between the outer diameter of the bolt and inner diameter of the insert and it's just beating the **** out of itself.
On another note, has anyone had any experience with diagnosing problems with sachs nivomat style rear shocks?
Now, Frick, What do you say?
http://www.wfoconcepts.com/pr/3-4-Bu...Bolt/3190/3499
http://www.wfoconcepts.com/pr/3-4-Bu...Bolt/3190/3500
Gracias
Pretty damn cool!
http://snip.awardspace.com/
I thought that one might have let you print a template that you could wrap the pipe with, but I guess it would be a decent way to get pretty close on the notches.
I had a vibration show up in my front driveline.
Found play in the front yoke, pulled the drive shaft. I thought it would the pinion nut just needed to be re-torqued, but it wouldn't budge. I figured this much play was not good.(?)
http://i70.photobucket.com/albums/i1...h_PB170124.jpg
So is this from a bad pinion bearing or are the gears on their way out? I have not pulled the cover off and will not have time to do so until Sunday...
