What kind of differential do you have? and I'm assuming the axle-shaft u-joints are good?
Best thing to do is open the cover and take a look. I should be in town this weekend if you need shop space.
Being as old as your jeep is I bet you have a combination of worn gears, bearing, spider gears, axle-shafts and hubs. I suggest driving the piss out of it until something breaks.
That would set me up for not being able to wheel at Clayton. I was leaning towards the gears about to take a ****, but I don't know too much about diffs.
If this is not an easy or cheap fix (less than $200), I would prefer to find another D30 or HP30 with 3.73s and bolt it in. As much as I need to re-gear, I don't have the money for it right now.
sounds like pinion bearings.
Find a cheap rebuild kit on pirate or tx4x4 and take it over to that trans shop on 21 they installed my gears for $150 labor. Or wait until it blows up.
yep they will have to pull the shafts, carrier and pinion. No need to separate the ring gear from the carrier or replace the carrier bearings if you really want to do it on the cheap. But with complete install kits around $100 it would be worthwhile to replace the carrier bearings while you are in there.
Pull the caps on the u-joint while you have it out to check that all the needle bearings are there and it has plenty of grease. I have seen u-joints that 'had no play' on the vehicle be trashed once you get them to the bench. If they are good, then take the diff cover off and see what the gears look like. You can then see what the pinion is doing to give it that much play. If nothing else, it gives you a good excuse to change the oil in the diff.
I fail to understand why people think gears are so difficult.
Because all of the Jeep people say things like this, so I don't know who to listen to:
I just want something that I won't have to worry about and won't let me down.
If you'll help take a look in there to asses the problem on Sunday I would appreciate it. I don't really have money for gears/bearings/install. So if that is the case I will probably try and find a junker I can bolt in, even if it dosen't have the same gear ratio. Maybe I could lean on my parents to help out a little as a Christmas present.
O'rieleys sells all bearings seperately so you can just get another pinion bearing if everything looks alright when you tear it down.
if you are just changing the bearing nothing changes with the gear set just put it back together.
Sharpe is correct as well.
You do realize the pinion bearing you can probably get off fairly easy yourself, but the carrier bearings will require alot more effort unless you have the right tools to do it like a bearing puller or large press.
There is always a possibility that if the pinion bearing is going out that it damaged the machined race surface on the pinion, requiring the pinion to be replaced.
I say we stop playing possible things wrong and what might be ****ed with fag wagon, and wait till Travis God of Gears can inspect it.
:flipoff2:
What you're saying is very unlikely. Bearing would have to lock up to spin the race.
I can't tell from the picture, how much play is there? A certain amount is normal for axles with some miles on them.
:laughing: :gigem:
yes unlikly kolpeckers, but I have seen it happen on kevin's camaro 9". Just a friendly reminder that while he has it out to check the surface to make sure it is not f*cked.
Nothing worse than replacing parts of a system with new parts to find out the other half of that system is f*cked.
there is nothing that rolls around on the pinion, the only way a fed up bearing will effect the machined surface of the pinion is if the bearing actually spins, and even then if the surface can be cleaned up there is a good chance the new bearing can be pressed on, in this case it sounds like a worn out bearing
lucas
Remove front driveshaft, problem solved!
