I will have an entire TTB, I have spare axle shafts, I have 3.55 gears in it, I will also have 6" superlift coils, drop down radius arm brackets and the lift brackets, plus spare steering parts!
i had the super lift coils on my bronco, they werent bad, but no deaver coil
They flex better than stock, but they are not trail springs. They are a spring you can run down the road and not be scared of the wobble. I can tell you I can stuff the tire into my fender well. Frick had some super flexy coils, that are bad ass for off road, but scare the hell out of me when used on road.
These coils plus TTB will let you do this!
I really need the spindles though, backing plates are pretty easy to find, but spindles are either on an axle or non-existent. I'm going to get new rotors, calipers, bearings and warn hubs anyways. Thanks though.
I need a super cheap pistol grip for an AR in CS.
I have a stock A2 grip but I'm not in BCS.
ive got an extra. Just txt me this afternoon
Standard bronco for your 5 speed swap
http://collegestation.craigslist.org...252367806.html
or here
http://houston.craigslist.org/cto/2234830120.html
I already ordered parts for my E4OD. I'm just looking for 8 lug 10 bolt stuff and doors. I wouldn't buy a whole vehicle unless it had a ZF in it. Travis when are you getting your welder back? I want to make sliders.
