you think you would have figured this out after the first transmission
Because obviously different wasn't working
Found a source for splined stock to build a less-****ty front driveshaft.
http://www.grobinc.com/coldrolled/bushings.htm
From what I've read on Pirate I'd say yes. Enough male stock to build a front shaft and two splined bushings should be about $150 at most.
Got a link to the pirate thread?
Everything's back together now and here's the brace I built. The t-case/floor/frame clearance was really tight, so my options were prety limited. I could have used a smaller bushing but I had this one already so, meh.
http://i135.photobucket.com/albums/q...f/IMG_0640.jpg
http://i135.photobucket.com/albums/q...f/IMG_0641.jpg
http://i135.photobucket.com/albums/q...f/IMG_0642.jpg
so do you already have a non cracked tranny back in
Yes bitch.
is there only one bolt holding the brace to the 205?
