My original thoughts were similar to what Mike is describing...valve stuck open causing the compression stroke to compress the entire valve cover, and since the breather tube comes out on the side i believed there to be a bad valve, it would just be pushing the oil that lubes the upper head out that breather, and also could be compressing down the runners that lead up to the top of the head.
BUT...
I did the compression test today with the help of Seth, Kate, and Landon stopped by on his way to class to run his mouth :D Here were the results:
#1 - 149 psi
#2 - 173
#3 - 161
#4 - 159
#5 - 35
#6 - 169
#7 - 165
#8 - 179
Adding a little oil to #5 then retesting compression brought it up to 58 or so. Bad ring? Can anyone let me borrow a compressor and valves i could do a leak down test on before I start to pull the head? Anyone got a driveway they dont need for a little while i could possibly borrow?
