There is a zf on craigslist austin
I've been too lazy to go out there. I figured somebody would have some laying around eventually. Carsten might sell me his cheap.
The 5 speed train has left until my 5.0 blows up then I'll see about finding a 460 and 5 speed combo to put in.
Edit: just called gordons, they want 75 bucks for a stripped door. **** that.
$75 isnt bad dude.
Maybe you should just buy this truck, it's GREAT running and a gas saver
http://houston.craigslist.org/cto/2257722421.html
Chevy 1/2 ton 44 spindles and outer shafts
What do you not need?
What I need is 3/4 ton backing plates, rotors, and calipers, and 1/2 ton spindles and bearings. I know 3/4 ton spindles have bigger bearings but I can use the warn lock outs I have now with half ton spindles. And half ton outer axle shafts.
(2) 16.5" rims with 5x5.5 bolt pattern style or width doesn't matter.
talk to karl
I don't need tires, how much? I'll probably take 3 if they're cheap.
I don't think they are what you are looking for, they are some 16.5" tires that I cut the center out of and welded a 3/8" plate with the 5 on 5.5 pattern in it. They are great for a trail rig, but I would not drive on the street with them. I have done 45 mph with em!
