or Free.99 out of the BMF stockpile of spare ignition parts.
Screw you guys, I'm going home.
Half-ass progress. Got the drag link off the pitman arm, track bar is gone, shocks out, coils are off the buckets and I just need to pull four bolts to get the links out - left them in to do some front axle figuring. Also, turns out the Jeep is light enough that I can pick the front end up off the axle now, that's how I made sure everything was unbolted. :)
Front axle choices. Next post has picture of steering/track bar geometry. Turns out the Chevy D60 has some stuff in the way of all that, so I'm thinking I may be better off swapping the Chevy knuckles on the Ford axle, or selling both and finding a Ford HP D60 and running with that. I need to do some more measuring on the Ford D60 I have to decide whether it's wide enough to work with the 14b rear and what to do about axle shafts.
Old steering and track bar locations.
http://www.texasoffroad.net/albums/l...aint.sized.jpg
Was it Maveric of Paul that painted your draglink?
Blake and Paul did it one weekend when I was in Eagle Pass.
Possible coil and LCA brackets, not sure what to do about uppers.
http://ballisticfabrication.3dcartst..._p_0-1542.html
http://www.pirate4x4.com/forum/showt...+coil+brackets
i've got an HP d60 for ya pm me if interested
Here's the Rubicon Express front axle bracket kit. Not sure what to do here, I don't really think either of the choices I've found are ideal for any D60 setup...
http://www.rubiconexpress.com/Img_Pr...aphs/0/590.jpg
Wtf do the shock mounts bolt on top of the kingpin?
what is that kingpin axle you have out of? looks like 78-79 ford but is it lp
It's from a 76 Ford - Just weird enough that you have to get creative with inner axle shafts to find stock length ones that will work. Not completely sure I want to use it yet but it's free for now so I may just set it up and worry about buying shafts when the time comes.
