i will get pics of the exhaust, brakes, "fuel cell", new fuel lines and brake lines, and whatever else i did those last couple of days and get them posted
specs
85 CJ7 LAREDO
304 AMC V8 - bored over .30, cam, motorcraft carb with electric fuel pump
TF 999 auto trans
Dana 300 t-case -1310 yokes, CV rear
108" wheel base
42x15x17 TSL
17" H2 rims
12k lbs mile marker winch
front
--- 84 cucv gm dana 60, full rebuild, 35 spline carrier-- welded, 4.56 gears, 35 spline 4340 chromo shafts, 35spline warn premium hubs, ballistic fab high steer arms- no kingpin spring, 7/8" TRE's, .250 wall DOM steering, all new brakes, 1350 yoke, ballistic fab 3/8" diff cover.
rear
---84 cucv gm 10.5" 14bolt, full rebuild, 35 spine carrier, detroit locker, 4.56 gears, disk brakes from a 77 k30 front, ballistic fab 3/8" diff cover, 1350 yoke.
suspension
--rancho 44044 spings, bilstein 12 travel shocks (22" ride hight), 6" shackles, hangers all recessed, 8 deg rebicon express shims up front, .250 wall DOM antiwrap bar rear.
driveshafts
--- houston drivetrain
front-- extra long splines, 1350 axle end, 1350-1310 t-case end 37 1/2" ride length
rear -- 1350 axle end, 1310 cv t-case end 30 1/2" ride length
steering
---PSC full hydraulic steering. 2.5" single ended ram, p-pump and external cooler-under bumper.
.250 wall DOM tie rod with 7/8" TREs
blue torch fab front bumper--modified, BTF flat fender kit and comp corners.
YJ master cylinder and brake booster-
4 wheel disk with line lock front. 3/16 to 4an lines
stock gas tank mounted in bed for now
all new fuel lines and brake lines down frame, new fuel pump, all new motor wiring
ran out of time for taurus electric fan that runs off 2 relay controls (no switches to forget)
rear bumper, paint, lots of grinding, new front shackles, new sliders (boat side style), grill hoop, redo rear brake plumbing
next is either pull motor and clean up for ditch the whole drive drain.
thinking about either old vortec motor, 5.3, 6.0 / nv4500 / stak or dana 300 with 4.1
