Originally Posted by JBrown89
			Steering 90% complete.  1.5" DOm 1/4 wall with Chevy 1 ton DREs.  The Ford knuckles must be a little thicker than the Chevy's b/c I had to notch down the castle nuts slightly to get the cotter through.
I ended up not using the brass filled knuckle.  Eric found a cracked 60 in Tomball that I got for $50 and used the knuckle off it.  I now have a small collection of 60 knuckles and shafts in the shed, all balljoint if anyone needs one...
-one driver's side reamed for Chevy from top, slider caliper, brass filled
-one untouched pass side slider caliper
-one drivers side reamed for Chevy from bottom but for bolt on caliper
My problem now is I can not fully turn left because the DRE on the stock pitman(mounted on top) hits the frame.  I ordered a drop pitman today and will ream it for the Chevy DRE from the topside and I should have no problems except that the draglink will not be perfectly parallel to the tie rod.  No biggie.
Next will be the brakes.  My stock rear shoes are toast, and I have all the parts for the disc brake conversion but from what I hear from Tate, its will not be as easy as I hoped.
My other BIG problem is the transfer case is pretty much up in the floor board.  I can not figure out why unless the trans x-member was bent upward.  Something happend at K-Rocks last year.  All of the bolts that secure the x-member to the frame are like loose.  I really don't know, something has to be in a bind.  I can't change the trans mount b/c I can not jack up on the trans enough before it hits the floor.  I guess the easy fix is a BL :D
Does anyone have a parts 4x4 Ford around?  I think I might need that x-member.
O, and my F150 torque converter failed causing some tranny damage at 30k.  It was assuredly my dumbass fault, but I dont think the programmer helped.
Ryan, check your box.
