Originally Posted by
FJAggie07
			Well if you want an 86-89 Runner you will be stuck with the 3.0 which is a less then steller power plant.  I like the coolness of the removable top but if you aren't set on that, but you want to keep your front axle, pick up a 95.5-97 Tacoma. They are driver side drop and will have the 2.7 or 3.4 in them which are much better engines.  Plus the Tacoma Transfer case while chain driven is extremely strong.  You could also go with a late 90's 4Runner (also drivers drop) which would be very cool for long over the road trips.
Or you keep your axles and get cheap 86-89 runner, you say screw the Yota Doublers  which can add up real quick and you get an Inchworm Lefty, or Atlas 2 speed.
