*waits for short shaft joke :eek:
Thats strange how two shafts thought to be 79 d44 where each an inch too long...
ya but the shaft you have could be broken and the remaining inch be stuck in the carrier. You would be surprised how cleanly the splined portion of a shaft can break off like that.
for instance here is a d-30 shaft that twisted and broke leaving an inch stuck in the carrier.
http://i47.photobucket.com/albums/f1...hevy/axle2.jpg
Yep, I have seen machine work not look as good.
just checked and the splined portion on the new and old shafts and they are identical. The end of the old shaft is not damaged.
then maybe you don't have a 79 axle under it? any applications that someone knows about that would be an inch shorter?
The inner axle seals are apparently different between truck and bronco housings of the same vintage so maybe the shafts are a c*nt hair different too.
They shouldn't be different, the only thing I can think of would be that the shaft is from a 76 or 77 model that had welded on wedges not cast. Call Clayton and ask to just go look at the set he has. I know for a fact that they came from a bronco78-79 Dana 44 because I pulled them myself.
Karl, you bringing the mini bike?
I really thought Rowdy would have a few 44 shafts back home.
i think i may sell my bronco and get a 92-96 one. Yes i'll get ttb (i heard its not that bad) but i'll get way more reliability too.
which is worse, ttb or ifs. i can't decide between the two evils
