I think Trout is where Knoeller's Dad got their trailer. They are a fine Porter based business.
You could probably get away with an 18ft car hauler with 3500lb axles. BUT, i would suggest 5200lb or 6000lb axles. When I was looking a few years ago, the price seemed to jump when you went to the 7k, but the one posted above seems to be reasonably priced.
Brakes on one axle works fine for me pulling the heavy Bronco with a half ton, but some will insist on both axles. I have heard rumor that brakes on both has caused inconsistent tire wear, but that could be a myth.
Make sure whatever you buy has new trailer tires, and not retreads
Steel deck v. wood deck is a toss up. You could hear arguements for both, but a treated wood deck is going to be a little lighter.
At 80inches wide, you are not going to need to worry about drive over fenders. My trailer is 83" between the fenders and I sqeeze all 86" of Bronco through them.
I would look for a 20' trailer, treated wood deck, dovetail, 2 6lug axles with brakes on one, 2 5/16th bulldog, good beefy tiedowns, LEDS, and new tires with a spare.
the biggest thing is that a treated wood deck is alot lighter than a steel deck
im curious what the weight diff is. the title on my work trailer says 211, which seems light to me.
if i were to buy another trailer i would get one a little longer, mine is 18 and often i could use another foot or two. so 20 or 22 but probably not 24. then agian i haul alot of random stuff around
mine is 18, the tool box is on the tongue so it doesn't take any deck space and the winch is removeable and any truck can pull up over it if it has to, still wish i would have gotten a 20 or 22
Mine's 12', you have 15" more wheelbase, so the next size up is 14'.
Mine is 16'. Of course my tool box is on the tongue. I can fit regulat cab long beds or extended cab shot beds. Anything else is too long. It is perfect for jeeps, reg. cab short beds, and any car.
see above for thoughts. (JB, I don't want this to seem like I am calling you out, but you just had a lot of what I wanted to comment on.) :beer:
Weight breakdown of Wood vs. Metal on a 84" x 20' trailer (140 square foot).
2"x12" pressure treated= 924 lbs.
1/8" plate = 714 lbs. (-210 lbs)
3/16" plate = 1078 lbs. (+154 lbs.)
1/4" plate = 1428 lbs. (+504 lbs.)
Information gathered from these two sources.
http://brownlumberservice.com/PDF/lumberweight.pdf
http://www.chapelsteel.com/weight-steel-plate.html
that weight for wood sounds like wet pressure treated i bet it gets alot lighter as it dries out. also steel plate is slick as hell when it gets wet and things like to slide around alot on the metal decks
once the deck is dry it will be closer to 600 lbs
and if you have to work on something and it is sunny out steel sucks, that and the coeficient of friction is higher on wood is why i got wood
I would rather have a steel deck any day off the week for any job. treated southern yellow pine(what most smaller trailer shops use) is not what real trailer decks are made of it crackes and splinters with any real concentrated weight. with a steel deck d rings can be put down almost anywhere so the load can be properly secured using straps no way i am relying on the decks friction.
who said anything about not using straps. thats just plain stupid
I think what he is trying to say is that if you are having to factor in the 'friction coefficient' of the deck then you are not strapping the load correctly to begin with.
it was also refering to when you are working on something when it is on the trailor and not totally strapped down
So you work on your trailer when it's sitting at a 45% angle??? :flipoff2:
Someone also mentioned using a winch as a tie-down earlier in this thread as well...
I bought my trailer without fenders and i decided that i should make it legal so it was time for some fenders. I wanted something different than a normal trailer fender and i wanted something that could be driven over and not have to worry about destroying the fender in the process. I went with the heaviest diamondplate fender I could find then used 1 3/4 .120 wall hrew to mimmick the shape of the fenders. Thanks to Karl for the extra help with the bending. They did not come out perfect but I am very pleased with how thet turned out.
While I had the trailer in the shop I removed the bent jack and replaced it with a new 7k. To make sure that the jack would not get bent this time I raised it up about another two inches from stock.
Next I needed somewhere to mount my spares. It sucks constantly throwing trailer spares into truck beds and making sure you dont forget them. I used some all thread( Karls favorite steel second only to angle iron) and some 3 inch sch. 40 for the current time(will get 5 inch when I can find some so that the trailer rim is perfectly centered on the pipe). Then to make sure everything stays tight I welded some nuts onto a four way to keep everything where it belongs.
more pics
I don't think those wheels will fit over 5" pipe, which is 5.5" OD.
That looks good! I need to cut off the old one on the white trailer and get a replacement one on there. Where did you pickup the fenders?
I'm looking at that picture, like "wait i thought frick lived in the country, look at all those yuppie bmw's, i bet his neighbors hate him with that turd in front of his......oh jesus that's my house, he just dropped it off this morning":)
Gooseneck on 21 sells thems.
I like the 4-way/tire hold down.
just drill a hole in the all thread and put a pad lock through the hole and they can't steal the tires either
true but if they are going to take it the atleast need to work a little for it
good work Kevin, looks good
http://tamor.org/forums/attachment.p...1&d=1267208500
you need to put a shackle in there so the spring has somewhere to move to. Had that set up on a trailer and it rode rough because the spring couldn't expand under compression.
Yep, leave the pivot in the middle and put the shackles at the outer ends.
EDIT: This puts a good bit of stress on that center pivot bolt, so make sure you check out that hardware good while you are doing anything to it.
they may be slider springs if so you don't need shackles
that is all assuming it is not a slipper spring set up, because if it is then it is set up right
You are starting with the wrong assumption, the correct one is: this is frick so it has to be wrong :flipoff:
I am pretty sure it is bolted on both ends of those springs.
Those are slipper springs, take a look under any heavier trailer. Ed, I would imagine your gooseneck has those.
I think you are right Kopecki.
