ive got a sye that you can have for cheap if you need one
is it the hack and tap or is it the shaft and all for the sye
it is the shaft, output housing and yoke
well i figured out why it had a rattle/knock, it turns out that the bolts that i had for the torque converter were too long and bottoming out and letting the flex plate move, so i added some lock washers and it cured the problem, but i got my brother to pick me a set of factory ones from jeep, so they are on the way to me
i also cut away the rear quarter panel, installed the grill, installed a tranny cooler (plate style), put the cowl back on and wipers on
just need to weld rear still, finish trimming rear fenders, make bumpers f/r, sliders, and adjust the front axle to get it centered all the way
i got the sliders/frame stiffener made and bolted on, made out 2" x 1/4" wall square tube the frame stiffener is made out of 3" angle 1/4" wall
rear bumper made and put on, made out of 6" c-channel with 2 1/2" sq tube 1/4" wall that wrap around the side towards the fender wells
and trimmed rear fenders and spot welded them back together
things left before clayton: make front bumper, weld rear, and adjust track bar and it should be ready
i have pics, but are still on camera, i will post them up later
here are a few pics of the progress
time to go finish this thing up
Nice!
clean work, me likey. :gigem:
looks good, but why blue? was that paint left over from the Robbie's Papa Smerf axle?
Originally Posted by nickas
:laughing:
important observation
blue, why not
it dont need no muffler
got the front bumper done today, just leaves weld rear, make battery tie down, and adjust track bar
Originally Posted by RCook527
don't you have tests or something???
yes thats why i have had less than 6 hours of sleep in the last two nights and am running on adderal and 5 hour energy shots. **** you :mad: :flipoff2:
today i changed the flexplate bolts back to the factory ones, welded the rear, and tried to adjust the front track bar over but couldn't
