It takes some power to run the solenoid. Sometimes the wire through the column and all drops too much voltage to power the solenoid. So you just use that wire to power a relay that powers the solenoid. It's common on samurais, I once installed one.Quote:
Originally Posted by RCook527
But that's not the problem here.
Here's my sure way of finding electrical problems, or at least easy one like this. Get your test light, its faster than a voltage meter. Find a wire related to the problem that should have power. If it doesn't have power work towards the battery, if it has power, go the other way. Your problem will be somewhere between where you have power and where you don't.
You got power to this switch yall are talking about? If not just skip it and go towards the battery. If you do have power to it, check if you get power to the other side of it when you press the switch.
