no. don't worry about it. i'm done.
make sure you have the centers all the way in the wheel when you go to weld them and that the wheels aren't out of round too bad. mine were a little and it caused them to sit in there crooked.
Vilas made me a new steering stop.
http://i736.photobucket.com/albums/x...IMAG0156-1.jpg
http://i736.photobucket.com/albums/x...IMAG0157-1.jpg
Bottom side machined out so it doesn't hit the seal.
http://i736.photobucket.com/albums/x...IMAG0158-1.jpg
Tie rod tabs, I went ahead and made them out of 3/8" since I had it laying around. (Mock up bolt)
http://i736.photobucket.com/albums/x...IMAG0162-1.jpg
Tucks up nicely behind the tie rod.
das pretty.
No bead stiffeners?
I think money was tight. These were to be used at tcc but we ran out of time to mount the tires.
hope you can get these studs out if you f them up
There's enough room in there to put a new one in.
did you even lay out the welds so the wheels would be close to balanced, I would have welded it solid all of the way around.
It was 4 in the morning and I thought I had measured them out all of the way......clearly I didn't. I'm going to fully weld them before I put them on.
As far as rock rings, they're on the list but I am out of money.
Plenty of room on mine to put in a new stud (if you can find one), put the nut on, and pull it in with an impact. Think I have the same centers and doubt you are going with tons of backspacing.
