83 Waggy and Parts
STOCK Front and rear leafs. $100
5 36X12.50X16.5 Military Goodyears old style with 7 16.5 wheels, 5 are mounted and ready to go. 2 wheels have tires that are bad on them. Yes there is tons of dry rot on these things but they still hold air/stand up on their own. Obviously would not drive with these on the road!!!! $100
I have an aluminum adapter for the 350 to a 231 also. $60.
Stock Cat and Flowmaster 50 (2009) with about 8ft of pipe all welded together. 2 3/8 pipe in front of cat and 2.5" at end. $60
Everything located in St. Hedwig, East San Antonio.
Only trades at this time would be an auxillary fuel tank w/ or w/o pump.
Clayton 210-eight.63(one4three.5%)
you don't still happen to have your old small bearing spindles, caliper brackets and calipers laying around do you?
Yes I have all the original 5 lug slugs, brake hardware etc.
I'm in need of a 5 lug setup. Do you have ford parts or did you mean 6 lug that the waggy had. I'm in need of the chevy/jeep small bearing 6 bolt spindles, backing plates and calipers and ford 5 lug rotors/ bearing hubs
The waggy stuff is 6 lug. Don't know if its the same as chevy stuff. All the stuff I got from you I used I think.... I'll look. Send me your number again, cell above in first post.
If you end up planning on scrapping the body, let me know. I could use a small patch panel from the cowl.
Send me a pic of the area/s you want. My floors are good, I think. Plan is to pull axles and put body on trailer this weekend. Cell above. You can just send me shipping, unless its too big we can work something out.
http://i30.photobucket.com/albums/c3...ps724736f0.jpg
Basically I just need this part. The dented portion of the cowl in this pic off the passenger side. Gladiator has rust through right underneath the top body line.
2-3" off the top of that top body line down to the bottom of the cowl panel where it meets the top of the fender should do fine. And it won't be a super big part to ship.
Just let me know what shipping is. Thanks! :beer:
You getting out of the 4x4 game Clayton? Or hopefully upgrading?
Kasey, I will try to get a pic of that area on mine tonight.
Karl, i'm putting jeeps on the back burner for a while. Just don't have the time or money and would rather spend said time and money on hunting stuff.
Kasey, the panel that I have is pretty dented right at the joint with the door frame. I'll put a pic up tomorrow.
Axles are pulled and ready for pickup.
83 stock radiator - replaced 2008ish. Has aftermarket trans cooler and auxillery cooler for power steering. $150
[IMG]http://i1197.photobucket.com/albums/...ps1r03v3si.jpg[/IMG]
Chevy 350 to Waggy engine mounts. Never used only bolted up once. $140 tyd.
http://www.bjsoffroad.com/prod-503.htm
[IMG]http://i1197.photobucket.com/albums/...psqa2johp2.jpg[/IMG]
Price updates in original post.
i forgot to call you last weekend. i guess i need to look for someone who is coming to houston. or if you want to see if you can fit it all in a flat rate box or two i can pay pal you money
Yeah we didn't get to make through there anyway. I'll grab a box sometime and see if I can get it in there.
