Ryan's spring cleaning of dexter
i've got someleft over stuff that is free to a small compensation depending on the item.
-(1) stock cj roll bar, garnet colored.
-(1) dana 44 passanger side knuckle that is f'ed
-(1) passanger side ford vent window frame and glass
-(1) stock 2 piece axle shaft AMC 20
-(1) cj slave cylinder and braided line
-(6) 2" 2 degree shims
-(4) 2.5" 2 degree shims
-(2) tow hooks
-(2) M.O.R.E. cage to frame tie in brackets, (look like body mounts)
-(2) cj7 4" lift rear springs
-(2) cj7 4" lift front springs
-(2) dana 30 hubs with wheel bearings, spindle nuts and washers
-(2) dana 30 rotors
-(2) dana 30 lockouts AVM
-(2) dana 30 knuckles with tie rod flip already installed
-(2) b2 front sping plates 2" wide springs
-(2) dana 30 spindles
-(2) front braided stainless brake line 4" lift
-(1) rear braided stainless brake line 4" lift
-(4) dana 30 brake pads
-(2) dana 30 calipers
-(1) cj7 rear driveshaft, 1310s non cv
-(1) cj7 front driveshaft, 1310s non cv
-(4) rear shackles 2.5" wide springs, 4" long
-(2) front shackles 2" wide springs, 4" long
-(1) dana 30 short side inner shaft
-(1) skyjacker nitro shock
post up for more details or stop by dexter
THE spring cleaning of dexter
...everything MUST GO! :flipoff2:
