Originally Posted by
85cj7
Glad you made this thread. I started my 9" build today too.
F-150 housing
Narrowed to stock cj width
Big Bearing Ends
Currie nodular third member
Moser Engineering 35 spline shafts and spool
4.11 gears
Trussed/Shaved
8.8 brakes
Pinion guard
My housing doesn't taper so I can't help you there sorry.
I'll either going to re-use the ends or get some from flem.
I'm hoping to get the alignment pucks and rod from creighton, who I heard had has them now.
I'm not sure what kind of truss I want to do either. Im thinking rear facing instead of on top because of the complications of spring perches and antiwrap bar brackets.
I just tore mine apart today, it was from a '82 f-150, had 31 spline shafts, crappy a$$ drum brakes and 2.97 gears in the thirdmember. All of which I'll be selling.
