Will not hold for you. First come, first gets.
Dana 60 rear 30 spline shafts. Fit ford truck axle. Think I have 3. $10 each
Dana 60 front drive flanges, dodge external, 30 spline. Have 2 or 4 to get rid of. $10 each.
D60 high steer arm. Used, drilled 3/4" straight thru. One only. $20
CJ aftermarket steering box mount. $25
CJ drop pitman arm, I think it's 4" and procomp brand. $20
Hydraulic cylinder. 1.5" bore x 8" stroke. Used, but I never used it, so not sure how good it is. Is an industrial tie rod cylinder so easy rebuild if it leaks. $25
Chevy d44 front long side inner axle shaft. $10
