The bald one is leaking air. I need to move it to a spare. Looking for a 42" tall 15" wide Tsl with good tread. Preferably 16.5" rim size.
just install on board air and you will be ok
Your sticking with those 42s?
Really only one is bad. Two have alot of tread on them, the other is still ok.
Once I have the beadlocks on it won't be an issue.
why? want to sell your iroks?
Not yet.
Just not sure what those 42s are good at. Not rocks, not jack-off go fast, not mud if a couple are bald.
Did you sell the 37s?
Is that suppose to make them good?:flipoff2:
I do not think anyone is running that wide of a 42. Isnt it like 42"x 2' on like a 15x20 rim?
They were way out of place on Katemcy rock. They bounced Faggie's Dad's FJ around in Clayon. They are heavy as ****. They seemed to work ok on Evans.
BLASPHEMY!!!!!
I'm broke, I got the whole set for the price of one new.......
I could use a spare 42 if you run across anything for cheap
they are 42x15's just like all the other 42 inch TSL's.... And they are God's tires
They bounced that 40 around cause they were aired up too high. I got them down to about 5 psi for our last trip to krocks and they hooked up fine and wrapped decently. There isn't a lot of choices when you get over 40" but I will admit they are freaking balloonish. Run what you have I say until you have to buy different ones or can't live without different ones. :-)
I am an irok believer. Only TSLs I have seen that work well are extremly worn in, more than likely from running them at low pressure constantly.
When i graduate i'm getting iroks........49"
DavidO's TSLs work great but i don't think he runs but 3 psi in them
Boggers /thread
Pitbull Rockers... Although I won't know how badass they truly are until I go to Colorado next month. Btw. Just cause they are 15" wide doesn't mean you need a fat rim. I have my tires on 8"
If you do that, you don't need beedlocks!
Most everyone who runs the pitbulls goes back to tsl's in my experience.
Never had tsl so can't go back. Just wanted to try something not a lot of people have. Tires will likely outlive the jeep.
uh hello
Yeah I have 3 tsl's and beadlocks in the works. I don't need different tires, I just need one more.
I wouldn't mind having a 42" spare if you happen across a cheap set. I've never had a spare, but at least one of my tires has a plug or five in it I think. Wouldn't be a bad deal for a longer trip to BFE.
JB, you're the only guy I've ever seen totally rock IROKs. Before your rig, I thought they were total crap... now only mildly. :D
Brian did well with his on the general too.
Robbie does good with his, and Linda does well with hers
Lindas burped before beadlocks
