Preferably one from a 78-79 Bronco/f-150 to swap into a newer bronco.
Thanks
Thanks
What is your cousin willing to pay for everything?
We might be able to work something out for one of mine.
How much? And what do you have?
I've got the one under my truck now with a 4.56 pinion and no axle shafts. I have extra 4.10s ( I think ), the 4.56 ring gear, and extra stock carrier spiders and gears.
I also have tum tums old axle that I was going to bolt under the white truck.
Whats it worth to you? That CL guy wanted 400 with the truck and stock gears? What gears are you looking for?
ooooh...I could probably use those 4.56 gears if travis doesn't. :D
Sounds good to me...
Do you have radius arms, coil buckets, steering and trac bar to include? I would be more interested in the 4.56 gears too
I have...to look. I will look Sunday if not sooner. Seems like I had an extra set of radius arms at one time...
I def have one good radius arm and one bent. (Tommy's) If Tommy's had spring cups I have those too. Almost sure I don't have panhard or steering. I bought new stock steering and a superlift adjustable trac bar.
Mine has everything lockout to lock out and steering, coils, buckets, shocks, track bar, radius arms, track bar
Mine's painted! Seriously though, used shocks, steering, and trac bar?
Used paint or new paint?
when I sold seth my axle it had 4:10's, Chromo's with spicer 760x u-joints with full circle snap rings. No lower coil buckets but it did have the tie rod (bent as ****), newer drag link painted gold and a track bar. I think the radius arms were bent tho.
So it sounds like I have a track bar and drag link to include...and one non bent radius arm. I might have an extra pair somewhere. I always wanted to build some extended arms so I was planning on cutting a pair up.
