Hey guys posting up that I started ordering light bars and stock them now if anyone is interested in any give me a call or text 830-708-0331
All are Cree LEDs didnt order any of the cheap epistars
I'm looking for some that are around 4x2 inches.
Flood or spot beam?
Doesn't matter.
I believe his point was that if you're actually GOING to use the lights, flood vs spot makes a big difference.
I.e. for reverse light purposes, a spot light would be stupid. You want a wide beam so the area right behind you is illuminated thoroughly, not a spot light, which the lighting equivalent of a tractor beam, and would only really be good for melting the retinas of tailgaters, or if you were reversing at 90mph through the desert. (Which may be your intent, I dunno.)
And knowing Sharpe, his answer on what to eat would be "a dick."
I was thinking a $hit sandwich but a dong will suffice.
I have 2 flood pattern duallies mounted under my bumper, each pointed out about 30 degrees and it's by far the best lighting upgrade I've done.
How much are the flood pattern duallies?
One-hundred billion dollars.
I think I paid like 30 each for them but I got them last year.
$45 for club
