My truck is making a funny clicking noise when I drive it. It speeds up with RPMs. Is it possible that the torque converter is going out? It mostly does it in gear when I am driving or if I power brake.
Give us some help here... Edit, Which Engine, tranny, etc...
I'm going to ASSume a 350/350/203?
I personally have never heard of a torque converter clicking.
Oh and stop power braking :flipoff2:
I'm not sure where it is coming from. I thought it was the lifters, but I readjusted those and it still clicked.
Yeah sorry i was a little vague on what i meant, i edited before you responded.Quote:
Originally Posted by aggieblazer07
it's got a 350 with an automatic. The T-case says NP 241-C
It's a 91 chevy 1/2 ton
I would think motor noise not torque converter noise, but I'm no scientologist.
Have you checked the oil? Could be all filled with water from a leaky intake, get ya every time :D
I changed the oil yesterday and added some Lucas oil stabilizer stuff.
Do you have a limited slip?
Bad ujoint?
I'm pretty sure it isn't the u-joints because it seems related to the RPMs. No matter how fast I am driving.
but only in gear?
It won't do it if you rev it in neutral?
Ugly's got a good point, I had a bad u-joint once and I thought it was my detroit messing up... but it goes with RPM and not speed?Quote:
Originally Posted by uglyota
It makes the same sound at 10 mph that it does at 30 and it speeds up when I give it gas. And it doesn't seem to do it in park or neutral when I rev it up.
have you checked your tranny fluid?
I did that earlier, it was fine
dunno man, btw you've probably got a 700r4, in which case a tranny problem is very likely :(
how about motor mount. The fan could be hitting the fan shroud.
im no scientologist either but since it doesnt seem to be doing it in park or nuetral i would think bad u joint, or something in the rear axle like a limited slip or something like that is messed up, and especially the limited slip if you power brake it alot.Quote:
I'm thinking ujoint too. Put it in gear and power brake the vehicle in drive and reverse to see if it makes a poping or clicking noise.
if it was a u-joint it wouldn't speed up when it downshifts
if it's rpm variable then its tranny forward, if its speed variable then its tranny rearward...or forward in the case of 4wd. so, if it's rpm variable then a bad u-joint isnt the problem. since an automatic transmission is a magical box to me, and im not sure what's inside, i dunno if it could be in there or not. never heard of a t converter tapping, but then again ive never had one apart and dont know whats inside. i know how they work and there should be no touching parts to be clicking.
check for exhaust leaks. it could be a small exhaust leak or blown head gasket that only shows up when the engine is loaded. exhaust leaks sound like tapping lifters all the time. when the engine is loaded, the cylinder pressure is higher because its actually having to push against something rather than just accelerating the piston. a good way to check for this is with a peice of vacuum hose. put one end in your ear and listen for small leaks around the heads and manifolds. like listening for vacuum leaks. of course not when your driving, just sitting in the driveway. unless you can find a buddy to drive for you and you can sit on the fender with the hood up and cruise around town.
How did you adjust lifters? You swap in solid cam and lifters?
Or maybe it just likes to make noises. All 3 of my jeep motors have allways had ticks, and the latest one still runs.
I backed off the nut on the rocker until it started clicking and then tightened it until it stopped clicking. Then I turned them each a quarter of a turn. I did that trying to stop the occasional clicking, but after driving for a week the clicking happens everytime I drive it.
that could possibly be your problem. ive never adjusted rockers with the engine running. im not sure how the lifters being pumped up affects the adjustment. my guess is that they are fully pumped and if you adjust them this way then it leaves no room for error. kinda like running a solid lifter cam. could be the explaination as to why it comes back after a week or so. the way ive always done it is with the engine off, tighten the rocker nut until there is no up-down play in the pushrod, then tighten another 3/4 turn to center the lifter plunger in its stroke. you have to do this when the valve is completely seated. ive always done it by rotating the engine back and forth until i could tell there was no lift. but, if you wanna do it right, find TDC for cylinder #1 and do both valves for it and the intake valves on #'s 2,5,7 and exhaust on 3,4,8. then rotate 360 degrees and do 3,4,6,8 intakes and 2,5,6,7 exhaust valves.
edited to note: you rotate the engine 360 degrees, this does not involve doing the hokey pokey or shaking it all about
agjohn's method is what they use at Vilas when building SBCs.
hows about putting the rear end on jackstands, put it in gear to get the wheels spinning and see if you can hear something different then?
mr saftey says yikes this sounds like a bad idea :flipoff2: . i would try what ag john says and yes exhaust leaks can sound like a lifter tapping my damn bronco has two exhaust leaks and sounds like crud.Quote:
have you ever seen ferris bueller's day off when they were trying to rewind the odometer on the old ferrari?
I didn't say to throw every stitch of common sense you have out the window, stick your diff on a pile of firewood and throw 'er in reverse. :flipoff2:
ask kopecki how he balances a driveshaft
I'm pretty sure it isn't the lifters, I adjusted them and nothing has changed. It might be something loose on one of the pistons. It doesn't sounds pretty at all. I have made some more observations, it only does it when the rpms are steady or speeding up, not when it is slowing down. I might be putting a new engine in this weekend. 267,000 miles isn't too bad on one engine.
did you check the simple stuff? Fan clutch? A/C compressor?
Nooooooo, you cant just put in a new engine without finding out what's wrong with it. we'll never know if we were right or not. plus, the fact that the engine beat you will eat at your heart and soul for all of eternity. be a man and find the problem, fix it if its cheap, then put a new engine in it. not only beat it but master it like the beast master you are. muuhahahaha
ahem, ok, your recent observations tell me that its more likely an exhaust leak. trust me, they usually dont sound like exhaust leaks. they have more of a mechanical sound
accelerating rpm= open throttle more air flowing through the engine and increased dynamic compression ratio results in higher cylinder pressure and intensifies the exhaust leak.
steady state rpm= still lots of air flowing, same result but not as severe
decreasing rpm= closed throttle, less air, etc. etc.
check your oil for coolant and your coolant for oil. if none in either it could still be a blown head gasket, just not by a coolant or oil passage. could be between the cylinder and outside.
scout guys always give me guff over putting a chevy engine in mine. this is yet another example of how a chevy powerplant is good for 300,000 miles as well.
If any of ya'll want to listen to it I can come by and we can go for a ride in it. It's hard to explain the sound with words.
i concurr with agjohn....exhaust leaks sound exactly like a lifter knocking when the engine is under a load...they are variable with RPM and not speed...and you wont be able to hear then very easily when slowing down. the ol' tube to the ear trick is very easily and will allow you to pinpoint where it is coming from.
if you decide to replace the engine and use the same exhaust system, you will more then likely still hear the same noise....unless it is coming from where the exhaust manifold/header mates to the block
it is not worth replacing the engine for such a noise. you should only do somethign like that when it leaks 6 quarts a week or has a whole in the side of it or something of the like.
It only leaks about a quart and a half a week. I crawled under the truck and couldn't hear any exhaust leaks.
just remembered, my dad had a similar problem, thought he had major problems. asked me about it and i took a look. ended up costing $20, including labor, to replace the donut gasket between the manifold and exhaust.
I'll check that
you not gonna be able to hear them very easily while the engine is not under a load. you are gonna haveto get a piece of tube and check the exhaust...or if it is a auto, you can have someone sit in it...putit in gear with their foot on the brake and revthe engine up some....they will be more apparent thenQuote:
would an exhaust leak cause the check engine light to come on?
generally not
now that your computer's throwing codes, take it to Autozone and have them read the codes for you.
