So back in Katemcy, with the help of some great Kopecki engineering, we replaced some blown motor mount bushings with washers to keep my rig wheelable. Well, I stupidly thought they worked well enough to keep them that way for all the little wheeling trips between then & now and my motor has evidently been moving around a bit. I need to find a permanent fix before Clayton, because it has moved over enough that the belt is hitting the (already shimmed & clearanced) PS gear box. Suggestions? Should I weld up some mounts to avoid continuing to blow bushings? Buy new advanced adapter bushings to replace the ones I blew?
Thanks for the help!
