Somehow I thought the tubing we had up at our shop had a smaller ID... Well no bueno, it's ID is too big.
Who ordered the tierod material so you can use a tap?
I do but it is going to cost you $.60 and inch
and you can tap my stuff at the same time
you mean as a trade for it? Or tap it in addition to buying it?Quote:
in additionQuote:
I fixxed the post you are to fast
Oh and I can send it to you along w/ my steering this weekend
You realize it sucks to tap it right? It takes a decent amount of time, plus my taps...Quote:
Do you need both tierod and drag link?
P.S. What material do you have anyways?
how bad is taping it, I am sure we can work something out.
The material that I have is an A513/5 1020 DOM 1.50x.375
Well it's fine thread...
So basically I chuck it up in the lathe and face it off. That takes all of 60 seconds. Then depending on how deep you want it, I sit there with a crescent wrench and tap it by hand using the tailstock to hold the tap concentric.
It just takes a while, probably 15-20 minutes a hole, depending on depth. Ask Brian Ritchey or Robert Sharpe, I'm not sure I've let anyone else do it. I think I let Garrett have fun also.
let me see, Ill give you the tube for $15 if you tap mine as well
And all this just costs you time since the school owns all this equipment. JEWQuote:
If you've got a manual lathe that starts at full speed tap under power. we do it all the time at work and it's never broken or dulled a tap. lowest speed and just bump it on and off, back it out when it spins in the chuck. Use a ton of tap magic or similar lube on the tap and run coolant on the outside of the material.
i know it works but it sounds so dangerous for expensive taps. i definately wouldnt let someone do that with my borrowed tap.
I'll bet I'm using more expensive taps than you are ;)
Just single tool the fawker with a boring bar.
Hi, I pay for taps! Thats why I let people come in and do it if they want and I don't charge them to use the machine.Quote:
P.S. Hello Pot!
yes, but the definition of expensive changes drastically when you are the one that pays for them. (i.e.- doug)
Tie rod and draglink?Quote:
Originally I told people $10 per link I believe. So each side was $5... Aren't weld in bungs like $10 a piece? I think $5 a side with me doing the labor is pretty good.
Yeah just single point the threads in place. Some kinda machinist you are haha. Who trained you anyway :flipoff2:Quote:
whats wrong with doing it that way?
Don't try to understand robert, just move on!Quote:
yeah tie rod and drag link, it sounds like a good deal since the tube is worth about $30Quote:
What kind of transport fees is creighton willing to pay for me?
15 is fine, i was just justifying my JEW expenses...Quote:
although, I hate pulling a crecsent wrench for an hour, but I do realize you had to go pick up the tube, etc...
slap on the ass? Search for the chadnutz thread, I think something like .36 cents a mile. You'll be rich!Quote:
Originally Posted by Reckless
Dude diesel was like a buck fitty back then, it has to have gone up to around $.54/mile.Quote:
beerQuote:
sounds good, you also don't have to get my tube done this weekend, ill grab it the next time I am down/around there or someone heads northQuote:
one of the few things ive never done on a lathe. looks easy enough. ill try it next time im in the machine shop.
http://www.pirate4x4.tv/lathelink.html
wow, I'm no expert but that video makes me cringe
I think if I ever own a shop I'd fire someone on the spot for storing the chuck handle in the lathe, and lack of safety goggles is pretty sweet too.
